88 Rear Disc Brake Rattle
Old Sep 4, 2004 | 02:23 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
CAN ANYONE TELL ME WHY THE REAR DISC BRAKE PADS ON MY 1988 TRANS AM RATTLE? I UNDERSTAND THAT THIS YEAR USES A "FLOATING" BRAKE PAD SETUP BUT IT JUST SHOULDN'T MAKE THIS MUCH NOISE. THE PADS APPEAR TO BE WAY TOO LOOSE ON THE CALIPER. THANX!
Old Sep 5, 2004 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do you ever use your parking brake?
Old Sep 5, 2004 | 06:59 PM
jms's Avatar
jms
I recently went through something like this on my '88 GTA.
Turned out to be the metal part of the pad (that rides against the caliper) had wore just enough to have some slack between the metal part and the caliper (front to rear) and it had a click-click type sound as the pad bounced forward and backwards at the worn spot.
I measured the difference at .080 (eighty-thousandths) and evidently that was enough to be noisy.
To temporarily check my theory, I spot welded a little tip at the worn spot on the metal part of the brake pad and filed it to fit within .005.
No more noise.
Then new pads.
jms
Old Sep 5, 2004 | 08:56 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
ive herd that you have to apply the parkign break every now and then because it adjusts the back breaks soem how or another... not sure about this but i know i herd that soem ware.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
