sway bar links
Old Sep 12, 2004 | 07:39 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sway bar links
i picked up spme replacemnt sway bar links, i followed the book at pep boys they are energy suspension good quality. The question i have is that my old ones are 1/4 inch shorter than the new ones, this is the metal piece that goes in the middle, does this lenght make a diffrence i bet it does.. how do i know which is right?
old ones measure 2 1/4 new ones are 2 5/8. i am installing eibach por kit springs whish are smaler springs so i may have to change these to something diffrent anyway.
it says on the box sway bar should be parallel with control arm.
Jeff
Old Sep 12, 2004 | 07:50 PM
JeffW's Avatar
Engine: 305 tpi LB9
if bars should be even i guess i would need smaller links? anyone know about this stuff.....
thanks jeff
Old Sep 12, 2004 | 09:51 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You should use the same length unless you have a modified supension. When intalled the swaybar lever arms should be level with the ground. Get the length that makes them so.
Old Sep 12, 2004 | 10:13 PM
CaysE's Avatar
Lowered car = shorter endlink spacer. It will be hard to tell without having the springs in and the wheels on the ground. Basically, take the endlinks off, put the car on the ground, hold the swaybar level and measure how big the spacer is going to be. Then cut the spacer. Install and enjoy. Serves 1.
Fanatic1074
Oct 3, 2022 05:57 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
