a little help on what these are
Old Sep 21, 2004 | 09:45 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I need one of these for my passenger side. seems one of the many times i've had the car aligned they've stripped it out any help is much appreciated. also where can i get them?
Old Sep 21, 2004 | 10:15 PM
84z4me's Avatar
Car: 84 z
Engine: 383
Transmission: 700r-4
Axle/Gears: 2.77 9 bolt
Easy, aftermarket.
Oh and they are strut retainers they hold your strut mount in place check your bearings if the mounts are that bad the bearings could be shot.
http://www.hotpart.com/index.php?p=s...id=3&sub_id=28
Old Sep 21, 2004 | 11:48 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The link above is for the whole upper strut mount. The pic posted is of the lower support bracket that goes inside the inner wheelwell and is what tightens down the strut mounts...those are either a dealer item or a salvage yard item. If you need one, let me know...I have a set on hand.
Ed
Old Sep 22, 2004 | 12:49 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
well i was contemplating whether or not i was gonna go with the spohn set for the car, but i doubt they come with those pieces.... Does anyone know? and by the way EB in the future i'll be buying the 13" Hd brake setup from you, that i contacted you about before
Old Sep 22, 2004 | 02:23 AM
ebmiller88's Avatar
Spohn's upper mounts are the uppers only, no lowers. I've seen a post on those things before and IIRC, the initial poster did get new ones...I'll look for it.
Ed
Old Sep 22, 2004 | 02:30 AM
ebmiller88's Avatar
OK, found it... JamesC again. He's everywhere! He's got pics and everything:
https://www.thirdgen.org/techbb2/sho...hreadid=183622
HTH...
Ed
