Anybody have any good links, done it before, pictures, part numbers, and/or kits? Right now there is slop in the box that's pretty bad. About 10 degrees total slop on the input with no output movement. I tried adjusting the pitman arm but that didn't work. Seems like it's in the actual ball asembly so I need to take it apart. What parts do I replace when I'm inside or is the procedure just to clean, inspect for REAL damage, replace gaskets and "adjust" out the slop?
Quote:
Originally posted by ede
think you may find it easier to replace it with a rebuilt unit than rebuild it yourself.
They want over $200 for a rebuilt box. For that price I'm leaning towards saving up a paycheck for rack&pinion....Originally posted by ede
ouch, i might have one in my shed for less than that. in chicago right now. i'll check when i get home.
Thanks. I have a 2.25 turn box in Ohio that I'll be picking up in a couple of weeks. I hope it doesn't need a rebuild too. It seemed tight to me (crossing fingers).Originally posted by ede
I got the box, no play
, but I still want to pull it apart to inspect it's condition (junkyard box).
It turns, I just need to set the input torque and powder coat it. This along with the astro van steerign shaft should be done in a week or so. I'll have pictures.
One question, is the "rebuild" kit you can get from the parts stores all the same for these saginaw boxes? The price is only $30 and I think I'll only need the gaskets, just want to be sure.
Why is it out of ALL these members nobody has rebuilt their own power steering box? I can't find anything on the rest of the web either
http://www.chevyhiperformance.com/te...48_0406_steer/
This is all I found, I think they're all basically the same.
, but I still want to pull it apart to inspect it's condition (junkyard box).It turns, I just need to set the input torque and powder coat it. This along with the astro van steerign shaft should be done in a week or so. I'll have pictures.
.http://www.chevyhiperformance.com/te...48_0406_steer/
