tire size
Old Oct 25, 2004 | 04:19 PM
sean86sc's Avatar
Car: 86 camaro sport coupe
Engine: 355
tire size
Finally starting my third gen build that has been years in the making. Car is going to be primarily street/strip. Want to know what size tires will fit under the rear end without modifing the wheel wells. Fronts too if anyone knows. Thanks
Old Oct 25, 2004 | 06:30 PM
ZSnyper's Avatar
Car: Formula
Engine: LO3 5.0l TBI V8
Transmission: WC T-5
I have successfully run P275/50R15 on my car with no rubbing. You could probably run P295s w/ spacers.
Old Oct 26, 2004 | 07:10 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
165R15 for the front if you run 26" tall tires out back
205 75 15 for the front if you run 28" tall tires out back
good uniform look that way.
Old Oct 26, 2004 | 08:08 PM
sean86sc's Avatar
Engine: 355
Thanks for the info. I was hoping to run a 265-275 on the street and atleast a 28x10 with skinnies up front for the track. Sounds like I should be ok.
Old Oct 26, 2004 | 08:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A lot will be based on what springs you use along with your wheel backspacing.
Old Oct 26, 2004 | 08:59 PM
sean86sc's Avatar
Engine: 355
I have hotchkis springs that lowered the car 3/4" which I will most likely get a lot of that back when I start cutting weight. As for the rest that's why I posted. see what has worked for some of you guys.
Old Oct 26, 2004 | 09:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
if you intent on running a 28x10 slick, be careful with your backspacing. 5-5.5 works best, but EVERY car is different, no matter if it is close to the same setup.
goodluck!
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
