tubular a arm bushings? help!
Old Oct 26, 2004 | 06:58 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
searched and searched. NOTHING. is everyone happy with those clear/white looking bushings that come with the a arms?
im almost set on doing a full front end kit, BUT:
a friend of mine and i just put a set of LCA's on his 95z.... has these same type bushings.
anytime you hit a bump or a dip in the road, it sounds like someone is beating the bottom of the car with a wrench!
suggestions and opinions please. i dont want to waste 600 bucks and a weekend full of work to be dissatisfied.
how quiet is your tubular front end?
THANKS! :hail:
Old Oct 26, 2004 | 07:15 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
with the proper amount of lube it shouldnt be very noticeable.
Old Oct 26, 2004 | 08:33 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
so you run them, and they do make noise, even with lube?
Old Nov 11, 2004 | 10:20 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
What brand a arms are you using? what kind of bushings are installed? are your springs lowered also? just trying to get some info...let me know
Old Nov 11, 2004 | 11:26 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
stock iroc spring, PA a arm, and some cheap bushings they come with.
ive noticed some people complain of "rattling" action after the a arms installed. had a set of LCA's do this as well. its the bushings they incorporate. they are designed for a 1/2 bolt and the stocks are 12mm. what im gonna do is hone out the holes in the PA k member to accept 1/2 bolts and use locknuts to adjust the load on them. ive also got some grease fittings in the bottom of the a arms now, so hopefully nothing will leak or sqeak. im also gonna use rubber isolators on both sides of the spring, and contact cement some rubber stripping on the sides of the a arm perches.
ill have everything buttoned up by next weekend. ill post up with a flame, or great results. not sure which.
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
