need some help!!!!!!
my 87 SC is leaning to one side in the front at all times, i dont have time to get into detail i need to go to work but i was wondering if its the Struts or the Springs......thanks in advance ill read your posts when i get home.......
The struts have little to do with the loaded height of the suspension when static. If the car's not level, it's likely either a spring or the frame.
One other less likely cause is a preloaded or bent sway bar, and it's easier to diagnose. Just disconnect both endlinks, roll the car back and forth a few feet to settle the suspension, and re-measure.
