Raise suspension?
Old Dec 10, 2004 | 03:54 PM
GreenHornet's Avatar
Raise suspension?
I've got a 92 convertible which hasn't been modified and i'm curious if the suspension can be raised a few inches because i find the car a bit low to the ground (i've got back issues).
Old Dec 12, 2004 | 12:41 PM
Kandied91z's Avatar
how many miles?
if it has a good amount of miles just replace with stock iroc/z28 springs.
if you have a bad back put it on air, then you can have it really high.
Old Dec 12, 2004 | 03:12 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
not only could it be higher but driving would be better on your back as well.
Old Dec 14, 2004 | 07:22 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Mine was the same way (the car). The part # for those springs is moog 5665/5662.
LT1Formula
Oct 8, 2015 08:34 PM
