help with steering system.
Old Jan 8, 2005 | 09:34 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I hope that this is the right board for this. A while back my whole steering column had to be replaced. Well I had to take it to a shop and get it replaced. When i got it back the steering wheel was slanted, what i mean is that when i am driving straight, the wheel is slightly to the right. I took the steering wheel itself off to see if i could straighten it up, but it only goes on one way. How do i straighten it up?
Old Jan 8, 2005 | 09:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take it to a shop and have the front end alignment checked. You might have a tie rod-end out of adjustment.
Old Jan 9, 2005 | 01:10 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
...or a bent frame
...or improper/uneven tire pressures
...or a dragging caliper
Hope ya get it figured out! I'd check tire pressures first...then check brakes (since its free), and then check alignment. (Just in order of cheapest to more expensive).
Old Jan 9, 2005 | 06:52 PM
CamaroBoy84's Avatar
Car: 84 camaro
Transmission: hmmmm......
I think the colum can come out and rotate so you can set it straight again...if not ive herd that you can take a toe out from one side and a toe in from the other till it straightens...but i could be wrong
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
