GTA rim ?
Old Jan 14, 2005 | 08:44 PM
82knightrider's Avatar
Transmission: TH200C....700R4
GTA rim ?
I was wondering if the 16x8 gta rims will fit a 82 firebird s/e?If they do is there any problems I need to know about?
Old Jan 15, 2005 | 12:45 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes they will fit. Just be sure that you mount fronts on the front and rears on the rear. They are marked inside. Also there is a small spacer roughly .125" thick used for the rear brakes if you have drums.
Lon
Old Jan 15, 2005 | 01:19 AM
Thanks Lonsal
Old Jan 17, 2005 | 04:04 PM
slo406's Avatar
Car: 02 Echo/91 trans am
Engine: 1.5/6.7
Transmission: a4
Lon
Is this the reasoning for not being able to rotate the tires from front to back?
Doesnt that push the rears more toward the fender?
(looking into buying some diamond lace GTA rims)
How much should a set cost?(black)
Old Jan 17, 2005 | 05:50 PM
lonsal's Avatar
The spacers were used for steel drum equipped cars. Check this post as to why. The stock 16" aluminum rims (GTA, IROC & Z28) have a 0 mm offset on the front and a 16 mm offset on the rear. This is to compensate for the wider width of the rear. It effectively pushes the rear tires in by 16 mm (roughly 5/8" per side). This is why you can't rotate the tires/rims front to rear. Well, actually there is more to it than that. Rear offset rims on the front will contact the front suspension and you can't drive the car (the tire shops screw mine up all the time even when I've warned them of front and rear offsets and in my case tire directional rotation). Some people use front rims on all 4 corners so they can rotate the tires and rims front to rear, but that WOULD push the tires and rims out 16 mm on the rear.
Check out Classic Industries. They sell a set of 4 new black GTA style rims for $695, (not including new center caps).
Lon
Old Jan 17, 2005 | 06:13 PM
slo406's Avatar
Engine: 1.5/6.7
Transmission: a4
so for the GTA rims they actually are tucking the rear tires 5/8 's more under the car?.Thats def a good thing!
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
