Can you run rears all around?
Old Feb 5, 2005 | 12:28 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
I was wondering if on my 90 Formula if I could run half inch spacers and four rear tires all around. I know the wheels say rear only and front only on the inside, but I figure that is for the spacers not the actual wheel. Is there any problem with running four rear wheels and tires all round with the correct spacers so there is no rubbing?
Old Feb 5, 2005 | 10:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes you can. A few guys with the new style brake kits up front can run all rear wheels since the kits add .300"-.600" to each side, therefore getting rid of the offset of the wheel.
Ed
Old Feb 6, 2005 | 10:46 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
You have to run longer wheel studs though. ARP sells 12mm X 2 1/2"long aftermarket studs that have a .509 knurl and will pull right in with no drilling. They are much safer also with running wheel spacers because those studs have 190,000 tensile strength.
I ran IROC rears on the front of my car for years with just a 1/4" spacer so the rim would clear the iron caliper- but even with 1/4" spacers I needed longer studs for safety because the lugnuts just were not threading onto enough stud.
I still run 4 rears now but I have a totally custom front and rear Wilwood brake setups with 1/2"X2.970 .568 knurl studs.
Old Feb 6, 2005 | 10:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I prefer to run 4 fronts. no modifications required and gives the car a nice stance.
Old Feb 6, 2005 | 09:24 PM
LedZep's Avatar
so I cant do this on the stock brakes? correct?
Old Feb 7, 2005 | 10:47 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Like Zepher said, you can run 4 fronts and not have to change anything else. But without spacers of some fashion, the factory offset rear wheels rub when put on the front of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
