Its connected to my swaybar. Its broken. but what the hell is it?!?!?
Old Feb 11, 2005 | 02:15 PM
trans am dann's Avatar
Hi everyone, my car is a black 82 t/a thats really really stiff. Practically every suspension component on the car has been heavily upgraded, and to my leisurely delight, by the previous owner. My problem however is this: the rear swaybar has a threaded rod on each end that I assume had previously played a crucial role in the mechanisms main function of keeping the car flat. These rods, however, seem to have broken in half between where they go through the swaybar and where they connect to the rest of the car. I dont know A. What they are called B. how to get a hold of a new pair or C. If I am going to have to buy myself a whole new setup....Any info would be of great help, critical or non, I really want to get my machine out this summer and do some autocrossing!
Old Feb 11, 2005 | 02:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are swaybar endlinks, and they do play a crucial role in keeping the car flat. You should be able to get replacements anywhere, either with stock rubber bushings or much better urethane ones.
Old Feb 11, 2005 | 03:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Cheap too. Get the polyurethenes for like $13 a peice.
Old Feb 12, 2005 | 02:10 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
yeah definitely get the polyeurathane ones....from energy suspension....they make a big difference ...and they were only like 18 dollars a set of 2 at oriellys ....they are called swaybar end links i think ....also get the mounts that are attached to the axle since those are probably rubber and worn too...replace those with energy suspension
Old Feb 12, 2005 | 05:52 PM
Thanks guys, live and learn i guess.. I did find a sticker for energy suspension on the underside of the hood but i'll replace both sets of bushings anyway. I think the car saw at least one or two seasons of hard driving, and at 13-18 bucks a whack why not?!
Thanks again!
ZEEYAA
Apr 16, 2023 08:29 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
