Moog Springs
Subscribe
Feb 16, 2005 | 08:07 AM
where do i buy moog springs from? can someone give me the link? also does anyone know the rate for the moog rear spring? is it just stock replacement or can you order stiffer ones? i'm looking for stock height 175-200lb rears. thanks
Reply 0
Feb 16, 2005 | 09:54 AM
Your local parts store. Call around. Real parts stores, maybe not AZ, CSK, Advance, etc.
NAPA also carries Moog, but private-labelled with NAPA part #s. Costs a little more that way but you know where to go.
Moog's part # for the rears is CC635. It's about 175 lbs/inch. Approximately stock height.
Reply 0
Feb 16, 2005 | 02:59 PM
thanks for the info..................will check it out!!!
Reply 0
Feb 16, 2005 | 06:19 PM
I picked a set up from spohn moog springs for a 110 all 4
I think napa had them listed at 150 or so for both sets .
Dynodan
Reply 0
Feb 16, 2005 | 06:27 PM
Autozone sells moog under their name duralast. Same part numbers and all.
Reply 0
Feb 17, 2005 | 06:48 AM
thanks MKOS.......there's a autozone right near me!! is it true the stock rear coils were the same rate for the irocs, z-28s, v-6s...every model? i have a '83 z-28 and the rears are way too soft for autoX..i hope the moogs have a bit more umph!
Reply 0
Subscribe
