15" rims on disc brake 9-bolt??
Old Feb 18, 2005 | 10:47 PM
Winger4800's Avatar
Car: 2003 Corvette
Transmission: one that has 6 speeds
Has anyone run into this problem? I want to run 15 rims with drag radials in the rear of my 89 formula. it has the borg warner "aussie" rear end. The problem Im having is that the calipers rub the back of the rim. (15X8 4.5 backspace) I could probably grind down the caliper fins to make them fit, but what is the correct way to do it? will a 15X8 5.5 bs help?
Old Feb 19, 2005 | 07:20 AM
CrazyHawaiian's Avatar
Car: too many ...
I can fit the OEM 15x7's on the rear of my IROC, no problem. It also has a 9 bolt rear with PBR's. I'm not sure what BS the stock 15x7's use, sorry.
Old Feb 20, 2005 | 06:07 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Please don't grind the caliper. First off, it's not really good to destroy a perfectly good part; Secondly, it's not safe to take away from the safety of your brakes. Install a thin spacer from a rear drum car (Mine is a '91 RS) and put those on between the wheels and rotors, that should do it.
Ed
fasteddi
Sep 10, 2015 09:32 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
