10 bolt posi?
Old Feb 23, 2005 | 03:53 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
10 bolt posi?
I'm curious to know if my 88 has posi or limited slip? It's a 10 bolt, when I do burn outs, both tires spin, not just one. I am running 3.42 gears.
Old Feb 23, 2005 | 04:33 PM
colonboy14's Avatar
Car: Trans Am
Posi and limited slip are the same thing.
Old Feb 23, 2005 | 05:53 PM
Car: 88 Camaro
Engine: 310 LG4
i said both because some people call it one or the other. So...do I have limited slip in my rear end?
Old Feb 23, 2005 | 06:11 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check your RPO codes for G80 (limted slip).
Old Feb 23, 2005 | 08:11 PM
Car: 88 Camaro
Engine: 310 LG4
RPO code?
Old Feb 23, 2005 | 08:46 PM
colonboy14's Avatar
Car: Trans Am
Look inside your center console. There should be a big sticker with a bunch of 3 digit/letter codes on it. These are RPO codes, basically the options and other equipment your car came with.
Old Feb 23, 2005 | 09:26 PM
Car: 88 Camaro
Engine: 310 LG4
well, i looked, but the sticker is damaged in one part. I can see that one set of numbers does start with a G but the rest is missing any other way to tell, i looked on the door jams, i didnt look under the hood yet. Maybe by a vin lookup?
Old Feb 23, 2005 | 09:39 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
There should also be another sticker inside the locked compartment in the hatch. an easy way to tell if it is posi or limited slip is to jack it up and spin one wheel while in park. if the wheel won't turn, it is posi. if the other side spins backword, it is limited slip.
Old Feb 23, 2005 | 11:13 PM
colonboy14's Avatar
Car: Trans Am
When you say limited slip, don't you mean open diff?
Old Feb 23, 2005 | 11:33 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Nope. limited slip has a governor in it that locks up the opposite wheel when there is a few mph difference in rear wheel speeds. at slower speeds it does act like an open rear.
Old Feb 24, 2005 | 05:18 AM
ede's Avatar
ede
pull the cover and look, takes a few minutes and the oil needs changed anyway
Old Feb 24, 2005 | 09:34 AM
Car: 88 Camaro
Engine: 310 LG4
Oil has been changed already, plus, except for the ring/pinion, I dont know what i'm looking at
Old Feb 24, 2005 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Planning on picking up the fast car hobby someday? (like.... maybe sometime after you lose the T2 intake.... )
Then identifying a posi by sight is something you need to learn to do.
If you really care, and aren't just wasting our time posting on the Net, pull the cover and look. It's the only way to know. For you, same as for everybody else that asks this question.
There's literally dozens of pice of every style of stock posi carriers ever used in these cars, as well as non-posi ones. Do a quick search over the posts for the last couple of months. I know that I myself have posted several. All of mine are posi, I don't think I even have a non-posi in my posession, in any of my cars or sitting on the shelf. I usually throw them away when I accidentally get one. Oh wait a minute... I do have one probably .... it's in my old beater El Camino. Never took a pic of it though.
Old Feb 24, 2005 | 12:21 PM
Car: 88 Camaro
Engine: 310 LG4
Well, i dont plan on picking up a fast car as my hobby, I'm doing a V8 swap. and as for the torker, it was found to best for my budget. I might not be the smartest when it comes to cars as I'm a software engineer, but I love my camaro and any question I ask here is genuine. I'm learning as I go and tgo has been a great source for learning.
Old Feb 24, 2005 | 01:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like a V8 swap and "import slayer" and all that might indicate a bit of a hobby thing going on, although I'm such a moron, maybe I'm misreading the signs.... but don't worry, that intake will prevent it from being a "fast car" hobby. It'll be just a "car" hobby.
That intake sucks. I can't think of very many that are worse. Like so many things, there's a reason you got it cheeeep; and that reason is, it's actually worthless. It doesn't matter how good of a deal you think you got on it; if you paid more than the aluminum by the pound (maybe $1.75 or so for the whole thing), you got ripped. The car will go faster with almost any modern intake at all on it, than it will with that abomination.
Oh, and in case you want me to quit beating around the bush and come right out and tell you what I really think about it, I will:
I don't like it very much.
Get rid of it. A good bargain intake, that will make as much power as that POS you've got while using about half the fuel, is a ZZ4 one. You can pick them up on ebay all the time for around $100. You'll make it back in a month's gasoline bill.
Old Feb 24, 2005 | 02:08 PM
Car: 88 Camaro
Engine: 310 LG4
Ok, so what intake do you recommend since this is turning into a T2 basher. I have not bought the intake yet, the car is still in progress. Keep in mind i cant afford a $200 manifold. I'm running a 1406 Performer.
Old Feb 24, 2005 | 02:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
then save for another month.
Old Feb 24, 2005 | 03:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Feb 24, 2005 | 03:58 PM
Car: 88 Camaro
Engine: 310 LG4
Originally posted by RB83L69
Is there a cast # or part # I can reference, or did all the ZZ4 motors use the same intakes? Is it a dual pane, or single? what type of runners does it have, long or short? and remember, i'm running a 305 block, not a 350
Old Feb 24, 2005 | 04:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go to ebay, Cars & Trucks, Parts, type in "zz4" in the Search thing. Rocket science I know, but just the same....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7956448256
I have one on my 305. Works great. A helluvalot better than the Performer I took off.
Old Feb 24, 2005 | 08:13 PM
Car: 88 Camaro
Engine: 310 LG4
that is nothing more than a performer RPM manifold...
Old Feb 24, 2005 | 08:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. It's a ZZ4 manifold.
I have a stock L69 manifold, a Performer, a Performer RPM, and one of those like what's in the pic on hand at the moment; as well as a few others to compare to. They're all quite a bit different.
I think I'm all done here.
Old Feb 25, 2005 | 12:47 AM
Car: 88 Camaro
Engine: 310 LG4
Well, i'd like to buy it, but i'm not running any smog control or emmissions control, so is there a way I can block the EGR port, etc etc? or is there a ZZ4 manifold (aftermarket or factory) that comes non-egr?
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
