Impala SS rim fitment
Old Mar 3, 2005 | 12:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Does anyone know if the 17" Impala SS rim will clear a 13" brake setup? (I know about the bolt pattern issue and am converting to 5x5).
Old Mar 3, 2005 | 02:56 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Depends on the calipers your using.
I see your "current project" lists using Wilwood so you will be fine. Wilwoods will clear stock 16" Iroc alloy rims and the GTA 16" rims in dia. So the 17" Impala SS rims would clear fine in diameter. Even if they are 1/2" thicker casting, they will fit. No rim is going to be a 1/2" thicker thoguh, Thats just dead weight and a waste of alloy.
Old Mar 3, 2005 | 06:09 PM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
post pics when done
Old Mar 3, 2005 | 09:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Thanks for the info, Dean. I don't know about the actual exterior dimensions for the caliper compared to yours as yours are radial mount, IIRC, but I don't see that being an issue. I think my biggest concern is if they will clear on the sides.
redimp, I will post pictures eventually.
Old Mar 4, 2005 | 03:13 AM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
Cool, thanks! You might have figured out, I have one of those also.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
