Spring choices
Old Mar 7, 2005 | 04:47 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Spring choices
I am trying to decide what springs to run in my car, i want to remain close to stock ride hight but want to improve handling, i was thinking the Variable rate IROC springs? are they any good? let me know.
Old Mar 7, 2005 | 05:06 PM
Abubaca's Avatar
I was un-aware of variable rate Iroc springs.
I know that the Eibach pro-kit is only a minor drop if at all, and they're awesome for handling.
Old Mar 7, 2005 | 05:08 PM
92MaroRS's Avatar
i could be wrong, ill check the computer at work, ither way what ever the IROC's had, i know the rear springs from the IROC and my RS were the same part number.
Old Mar 7, 2005 | 10:32 PM
Abubaca's Avatar
I know for a fact that Iroc spring are MUCH stiffer than RS springs.
...at least up front, and I'm fairly sure it's that way out back too, although I don't have numbers.
Old Mar 7, 2005 | 11:00 PM
92MaroRS's Avatar
part numbers at work gave the same numbers for the rears, both are the variable rate springs in the rear(thats where i got that from) and the fronts are different, and are constant on the IROC.
handleing wise, how would the IROC's compare to the Pro kit Eibachs
Old Mar 7, 2005 | 11:12 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
That doesn't mean they were the same from the factory, just that a repro company doesn't want to stock two different rates of spring when most people would only buy one.
Old Mar 7, 2005 | 11:13 PM
92MaroRS's Avatar
correct, but this is what i have access to(at discount)
MrPackstin
Oct 25, 2017 08:09 PM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
