coilover sleeves??
Old Mar 8, 2005 | 04:58 AM
e-man's Avatar
Car: 89 formula
Engine: 383
coilover sleeves??
Does anybody sell just the threaded sleeves that fit over our struts?
Old Mar 14, 2005 | 07:28 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Guys that have coilovers what do you do if the threaded sleeve strips or something? Go and spend another $250-$400 for a now kit?
Old Mar 15, 2005 | 10:29 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
From my research, most of the companies use the Afco sleeves.
However, A word of caution, they are paper thin. They are made of .065 wall tubing before the threads are cut into them. I do know of one breaking first hand from a person that had it happen.
This info was given directly to Steve Spohn hence why Spohn has opted to ciuston CNC his own sleeves and threaded adjuster nuts to a perfect fit on our third gen struts rather that using a universdal one that is thin and has slop fit onto a 3rd gen strut.
IF you have a problem with a sleeve, it is good customer service for the vendor you bought your kit from to replace yours without the cost of buying an entire new kit- they have records of you buying one in the first place. Now if you only want the sleeve because you want to build your own from scratch, then you are most likely SOL and will have to measure and have a machine shop make two custom sleeves and nuts for you at about $400-500.
Old Mar 15, 2005 | 05:10 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Thanks for the info,I did want to build my own from scratch.Also I looked at the AFCO site and they dont show a size that will fit over our struts I measured 2.18 OD on KYB GR2's.As you say Im SOL
Old Mar 15, 2005 | 11:22 PM
Kandied91z's Avatar
i had mine cnc'd, much better in the end. you'll want 2.5" id for most struts and 3" for bilstein or larger setups. 2.5" is a very standard size for spring choices when it's time for you to shop, something to think about.
Old Mar 16, 2005 | 09:42 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Hm I'm pretty sure you can buy the threaded sleeves separately because I was at a guy's house a few days ago that had gotten an extra pair (one of his first pair got stripped). I'd considered building my own setup too, but I'm not sure how "worth it" it really is when you can jsut go and buy a setup pre-made for $400.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
