Will the S&W race cars subframe connector fit with a 4 inch mufflex exhaust system???
Old Mar 9, 2005 | 12:17 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hey guys, I am going to be running a 4 inch Mufflex exhaust system. I will also be using their 4 inch Y pipe(2 3 inch pipes merging into a 4 inch outlet designed to be used with Hooker super competition long tube headers) as well. I also had my heart set on using the S&W race cars subframe connectors(bolt in style that I would have welded in). After reading a post by a member, I am not so sure that this will all fit. Is anyone running this setup currently? I do not want to hack up a $650 exhaust system to get everything to fit. Or would I just be better with a perimeter style subframe connector? Any info/suggestions/opinions are welcome on this issue. Thanks, Paul Moore
Old Mar 9, 2005 | 06:14 PM
PhilM's Avatar
Car: Accepting applications...
I have seen the S&W set up a few times (it is a very nice product), and my gut tells me that it isn't going to work because of the crossmember. I am assuming you are going to use the S&W torque arm as well? If you were just using the connectors without the center piece and the arm it might be ok. Of course I haven't seen the set up with anything but open headers (stockers), so I can't say for sure. I just wouldn't count on it.
Old Mar 10, 2005 | 01:08 AM
Rembrandt's Avatar
This picture might help, if it works:
Attached Thumbnails Will the S&W race cars subframe connector fit with a 4 inch mufflex exhaust system???-c-documents-settings-administrator
Old Mar 10, 2005 | 01:12 AM
Rembrandt's Avatar
I don't have my camera right now otherwise I could take one with better respect to exhaust positioning.
I don't know anything about the Mufflex exhaust. If it follows the same centerline as mine it "ought" to fit.
colton_carlson
Mar 8, 2019 12:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
makaveli09
Aug 12, 2015 09:07 PM
1nastygta
Aug 8, 2015 07:38 PM
