best drag spring
Old Mar 21, 2005 | 12:31 AM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
best drag spring
what do you think would be the best drag springs would be. no street time just for dragracing.
Old Mar 21, 2005 | 06:52 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
For the front Moroso trick springs, rate will depend on engine you decide to use. I had great luck with those and using the 90/10 Lakewood struts up front.
Out back I've just got factory rear coils, but added Lakewood 50/50 shocks, a better upgrade for shocks would be the QA! Stocker Start AL shock since you can control the dampening.
Out back also consider installed at minimum air bags so you can control body roll-ie try to eliminate it. Or step upto a good anti-roll bar, not a sway bar.
Old Mar 21, 2005 | 11:11 AM
Car: 1987 iroc z
thanks i heard of people using v6 springs but really just wanted aftermarket ones would it be worth changing to coil over shocks or not.
Old Mar 21, 2005 | 04:03 PM
IHI's Avatar
IHI
Coil overs would give you alot more ability to really fine tune suspension adjustments. Depending on your budget factory rear springs with plain jaane 50/50 like I'm running seem to work just fine, consistent 60's likeI have mine set-up so I have no complaint. But if your a guy that just must have the best and all the bells and whistles the aftermarket has to offer switching everything over the coilover set-up would be the way to go.
For clarity sake the QA1 Stocker Star shocks are shock only, they are not a coil over set up, all they do is replace the factory shocks, and a few guys I've read that run them say they are great. I did the budget thing, basically got new struts/srpings up front and new rear shocks for the same price as the QA1 alone would've cost. Again, everything seems to be working great for me.
Old Mar 21, 2005 | 07:25 PM
zrotten's Avatar
If you have a .....
If you have a BBC in your car, I have a brand new set of Moroso trick springs I'd like to dump cheap?
Rotten
Old Mar 22, 2005 | 01:03 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i ran v6 springs with 30/70 competition enginering shocks on bfg drs. never ran at the track on a timed night, but on the street racing night, it was leaving hard. motor died before i could get to a t&t
Old Mar 23, 2005 | 09:47 AM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
front:moroso bb trick springs and lakewood 90/10 struts,no sway bar.everything else is tock but i would like to buy a tubular crossmember and a-arms .
rear:southside lift bars,lakewood panhard bar,stock springs,air bags in both to stiffen up the spring when neded and QA1 stocker star shocks which was the best investment i made.
1.37 60ft with a glide,3450lbs.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
tcflint
Sep 27, 2015 05:58 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
