IROC suspension
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You could check your RPO tag if it is still intact. Certain suspension packages are listed as RPO codes.
You could check the springs tags if they are still present. You can physically measure the diameter your of swaybars.
All these things should give you some knowledge of your '89 IROC's suspension.
mustangman65_79
Aug 11, 2015 03:17 PM
