New Spohn coiloves and a STB
Old Mar 27, 2005 | 08:26 PM
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
Hey guys. Does anyone know if the new coilover kit from Spohn would work with an edelbrock carb car strut tower brace? I am interested in them, but would like to keep my STB for sure, specially if I am running the coilovers.
Thanks.
Old Mar 27, 2005 | 08:32 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I asked the exact same question a month or two ago. I actually found the thread again earlier today by searching for strut tower bar
The conclusion was that his parts are designed for stock cars, so you will probably have to modify his plate system a bit to fit your bolts through.
Honestly, you're better off just welding in the STB bracket mounts. Weld them to the strut tower and that way you don't have any bolts going through the tower to interfere with his plate system.
Old Mar 27, 2005 | 09:55 PM
Igor's Avatar
Transmission: th350
This is what I wat thinking. Makes sence, as long as it would still be as strong as bolts.
Thanks man!
Old Mar 27, 2005 | 10:13 PM
Car: 1997 Corvette
It'll be stronger than bolts. You're always better off welding in suspension parts than bolting them in (i.e. subframe connectors).
Old Apr 2, 2005 | 10:11 AM
RedGTAWSU's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 350
Just make sure there is a way to take the bar out....u'd have a bitch of a time getting your engine out with a strut tower brace in that engine bay
Old Apr 2, 2005 | 06:35 PM
Igor's Avatar
Transmission: th350
well, if you just weld the two strut tower stb mounts, there should be no problem.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
