Koni Struts Too Firm ????
Old Mar 28, 2005 | 01:00 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Hey guys back in December i got my front struts/rear shocks replaced along with my springs on my 82 ws6 t/a.I have koni front struts and kyb gas-a just rear shocks and Moog springs.My problem is that they are too firm when my car hits train tracks or pot holes and rattles like a transit bus any ideas ??? Can i get a softer riding strut?
Old Mar 28, 2005 | 10:41 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Koni Struts Too Firm ????
Originally posted by 3rdgenparts
Hey guys back in December i got my front struts/rear shocks replaced along with my springs on my 82 ws6 t/a.I have koni front struts and kyb gas-a just rear shocks and Moog springs.My problem is that they are too firm when my car hits train tracks or pot holes and rattles like a transit bus any ideas ??? Can i t a softer riding strut?
Several things;
1: Make sure the Koni's are set to FULL SOFT. The adjustment on Koni's is actually only suppossed to be used to compensate for wear. Obviously racers will find other uses for the adjsutment.
2: New Koni's go through a break in period. They are extremely stiff when new. After about 5,00 miles they will soften slightly to their designed stiffness.
3: What Moog # springs did you put in. The new springs may be stiffer than the old ones...most likely in fact.
Tokico Illumina's are a softer shock BTW...if the Koni's don't settle down enough for you.
Edit: What Koni style did you get? The Yellow Sports or the Standard Reds? The Yellows are much stiffer.
Old Mar 29, 2005 | 07:04 AM
On Probation
Re: Re: Koni Struts Too Firm ????
Originally posted by Chickenman35
Several things;
Hi
1.I lost the adjusment ****
2.They were used not new
3.Fronts are 5608/rear CC635
4. Standard red
Old Apr 2, 2005 | 11:32 AM
nicksL98's Avatar
the rears springs are a problem, they are cargo coils, thick wire diam, meant to carry heavy loads and such.. get a pair of stock NNL rear springs and your ride SHOULD improve.
Old Apr 2, 2005 | 12:14 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Re: Re: Re: Koni Struts Too Firm ????
Hi
4. Standard red
1: Take a small crescent wrench and turn the adjusting " Tit" counter-clockwise till it hits the stop. This is full soft. Easy does it, takes very little effort. Do not force it past trhe stop or you will damage things.
2: OK
3: Fronts certainly soft enough. Rears are Variable rate or Cargo Coils and are stiffer than liniar rates ( I checked Moog's Catalog ). 5665's are the standard rear spring. Edit: Sounds like you were only complaining about the front stiffness though. Is rear OK?
4: OK
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
