TRW or Moog?
Old Mar 30, 2005 | 04:58 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
TRW or Moog?
I work at Advanced Auto parts and are higher up chassis products is TRW, how do they compare to the Moog products? I need to rebuild the entire front end of the camaro and was just curious what path i should take. here are my options
TRW Inner and outer tie rod ends, idler arm, centerlink, spohn HD tie rod adjusters, ball joints, and eibach pro kit and Bilstein HD struts and shocks price after my discount:$981.22
Sphons front end rebuild kit with the Eibach pro kit and the Bilstein HD struts and shocks. Price:$1117.10
which would you go with?
Old Mar 30, 2005 | 06:26 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Re: TRW or Moog?
Save some money, they are the same parts in almost every aspect. FWIW, i used TRW on my front end, better than the OE that was on there (because it was 20 yrs old)
Old Mar 31, 2005 | 12:46 PM
92MaroRS's Avatar
anyone else?
Old Mar 31, 2005 | 12:52 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Ive seen TRW products and they look good to me.
Old Mar 31, 2005 | 05:44 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
I've used both and never had a problem with either.
Old Apr 11, 2005 | 09:56 PM
92MaroRS's Avatar
I was under the impression that Federal Mogul made Moog Chasis parts, yet my TRW tie rod ends say Federal Mogul on them.
Old Apr 11, 2005 | 09:58 PM
Car: 85 Trans Am
Both are fed parts.
Old Apr 11, 2005 | 09:59 PM
92MaroRS's Avatar
Originally posted by Forshock 85TA
Both are fed parts.
so then are they both essentially the same part?
Old Apr 11, 2005 | 10:01 PM
Car: 85 Trans Am
I havent used the moog myself, but the pics i see no major differences
Old Apr 11, 2005 | 10:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
check federal moguls website you'll see
federal mogul = moog = trw
just like holley = flowtech...
however, spohn supports the boards, and with that in mind his customer service is great. I'd go that route.... just to give money to the right person sorta thing...
Old Apr 19, 2005 | 08:31 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
a little off topic, but good to see another AAP employee around here. we got 3 3rd gen owners at my store (and there's only 6 of us total at that store).
back to topic. go trw. lifetime warrenty (especially for us ), and pretty much identical to moog. and the discount sweetens the deal.....
Old Apr 23, 2005 | 12:32 AM
dopplereffect's Avatar
Car: 91 firebird TBI
Engine: Three SLow Five. LO3
Transmission: MAN 5 SPD B0RG WARNER, 77MM, 2.95
i am using moogs they are solid parts
they help me cornor like a muth
87v6Bird
Jul 1, 2018 04:12 PM
starfinder
Oct 25, 2015 10:40 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
TA8487
Aug 11, 2015 09:02 PM
