spring isolators
Old Apr 18, 2005 | 01:01 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
spring isolators
does any know where to purchase a set?
I have been two three local parts stores and noone can help me,
mine are shot all rotted out.
Old Apr 18, 2005 | 01:22 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Your local GM dealer should be able to get them for you. It has been a few years since I did mine but they were less than $10 each (actually I think they were closer to $5).
-Schultzy
Old Apr 18, 2005 | 03:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
z,
You might do a search before you buy from GM--"seems" to me that I read the current rears are really from fourth gen cars and make the rear sit up too high.
JamesC
Old Apr 18, 2005 | 04:09 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
so there is a diff. between 3rd and 4th gens,
how much thicker are the 4th gens?
Old Apr 18, 2005 | 04:40 PM
JamesC's Avatar
Check the following link:
http://pg.photos.yahoo.com/ph/tarami...c0.jpg&.src=ph
Hit "Next" at the bottom of the pic and you'll see the isolators in better dimensions.
As I recall, the car sat up high enough that Ed pulled them and reinstalled the old ones. All this from memory--and I'm an old fart, so take what I say with a grain of salt!
JamesC
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
