Wonderbar Question
Old Apr 21, 2005 | 08:00 AM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
Wonderbar Question
I got my Wonderbar from Spohn yesterday, and I can't wait to put it on. My question is which side mounts where. The directions say the side with 3 holes gos on the passenger side, and the one with 2 holes gos on the driver side. Simple right, not really. The bar itself has the sticker mounted the other way, and the side with 3 holes has an L on it, and the other side has a R on it. Now if I'm not mistaken L is driver's side, and R is passenger side correct? I've done a search, and looked at the picture on Spohn's site, but can't see which side is which. Also do you need to remove the other 2 bolts on each side to get the brace in, I held the bar in place yet, but it looks like it's going to hit those. Thanks in advance.
Old Apr 21, 2005 | 06:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
it can only go on one way. You will see when you line it up to bolt it on. Don't worry about the sticker. i think mine was off as well. I think it is so that you can see it when you look down from under the hood. I had to wallow one bolt hole out on the passenger side because the hole seemed to be a good bit off.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
