adjusting spohn panhard rod
Car: 1990 firebird
Engine: 3.1 v6
okay so i lowered my car about a month ago now and i have messing with my rearend to get it aligned and i cant seem to get it. is there anyway i can do this while the panhard rod is on the car? i take off of the end where the adjusting nuts (?) are and usually turn it so it gets tighter. I dont even think im adjusting this the right way, help anyone? i seem to tighten it so my pass side comes over and it seems to be the same!
Car: !986 Firebird
Transmission: th350
The nut is actually a lock nut that is used to lock the end in place. You need to remove the end where the nut is located you then lossen the nut and screw the end of the panrod bar the way that is needed and then tighten the nut back down and reinstall.
Later Bddbrd
Later Bddbrd
Hotrodboba400
Dec 10, 2019 07:07 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
