torque specs for prothane bushings/endlinks
Old May 15, 2005 | 11:37 AM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
I was just curious:
What are the recommended torque specs for tightening the endlinks to the body of the car. Also, what are the recommended torque specs for bolting the sway bar bushing brackets to either the rear or the body in the front. thanks.
Old May 15, 2005 | 12:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Sway bar mount bracket bolts: 37 ft-lbs (50 Nm), End links: 16 ft-lbs (22 Nm). What, the instructions with those kits didn't supply the torque specs? Mine do.
Lon
Old May 15, 2005 | 12:10 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
if they did have em...i didnt see em...thanks.
Old May 15, 2005 | 12:18 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
by the way, the 4 washers that came with my 36 mm greaseable front sway bar bushings...do they just go on the outside of the bracket when I got to bolt em down, well up in this case.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
