Weight of Chromoly parts
Old May 15, 2005 | 05:29 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
In general do Spohn's Chromoly, Adj-PHB, LCA's weigh less then the stock stamped steel parts. I see there front A-arms weigh less then stock!?!
Old May 15, 2005 | 05:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yes they do. The poly/poly adjustable ones are the heaviest... They weigh exactly as much as the stock ones. lol
Kat
Old May 16, 2005 | 09:25 AM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Exact same weight huh, not even a pound lighter Well atleast they aren't heavier. Suck to get the non cro-mo ones then.
Old May 16, 2005 | 10:55 AM
83 Crossfire TA's Avatar
For that matter, 4130 (chrome molly) will weigh exactly the same and have the same strength as the same part made in the same thickness mild steel (1018 or 1020, 1025 if you can get it will be stronger and cheaper) unless someone goes to the bother/expense of having the whole part heat treated/hardened after it is manufactured/welded. For the life of me I can’t figure out why people are so eager to use 4130…
Old May 16, 2005 | 11:49 AM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
So there is no benefit to Cro-mo over the mild steel?
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
