another annoying topic for you guys (popping)
Old May 25, 2005 | 07:23 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
before anyone yells at me , i have searched okay. I have been getting this real bad pop in my car for about two months now. At first it would only happen when i launch hard but now i hear it when i am slowing down or just crusing at low speeds. . I checked tranny mount and little square rubber bushing, its all there and in good shape. I have checked for any type of play in the front suspension. I have lifted the wheels off the ground and grabed the 3 and 9 to see if there is any play. I do see movement in just about everything from the center link to tie rod. BUT i am guessing this is due to the play in the actual steering box. The tie rods do not have any slack BUT they do twist rather easily. Are they suppose to twist at all? I have checked the ball joints by putting my jack under the tire and lifting it to see if i see any vertical movement in the ball joint.( of course while the car on jackstands). I do not see any slack. I also grabbed the 12 and 6 position on the tire and there is no movement at all. i have replaced wheel beerings. I just did my calipers and hoses and pads a few weeks ago. Greesed everything up so it cant be that , No the clip isnt off the pad either i even bought new ones (old ones came off to easily). I am running out of ideas here , my struts are shot , kyb of course . Would it be my tie rods causing this? i can hear it on both sides
Old May 25, 2005 | 07:35 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Make sure the six bolts holding the k-member to the body are torqued to 120 ft-lbs.
Old May 25, 2005 | 09:46 PM
Car: 1990 firebird
Engine: 3.1 v6
thanks i was hopeing someone would tell me how much torque the kmember needed to be torqued. I read that in one thread and didnt get a response. Im going to give it a try this weekend. Any other ideas fellas?
Old May 27, 2005 | 05:47 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Sorry to hijack the thread, but I get popping too. However, mine only happens near full lock.
I looked at the k member an thought those bolts haven't been moved in years. Anyway, out came the torque wrench. YEP! They moved all the way to 120 ftlb.
Hmm. still get popping though..
Cheers
Mark.
Old May 27, 2005 | 11:33 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Cheers
Mark.
I've had the same problem on my car for years now. When pulling out of a driveway or something it'll "pop" as if something is binding up - No idea what it is. Otherwise the car feels fine, goes down the road straight, doesn't make any weird noises, nothing. I'm beginning to wonder though...
Old May 28, 2005 | 05:40 PM
TexasLT1's Avatar
Car: '92 RS
if it is when you're slow and near full lock its the upper strut mounts.
Old May 28, 2005 | 06:17 PM
Car: 1990 firebird
Engine: 3.1 v6
yeh the only way to take care of this is a front suspension rebuild.. I was told one time the upper strut mounts , but then again i feel it by the flooor board.
no one really answered my questions about the tie rods. Are they suppose to twist easily?
Old May 28, 2005 | 10:58 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
Mine did the same popping at low speeds when truning outa a driveway or almost to the lock. I put some grease on the bump stops and it went away.
Old May 29, 2005 | 08:28 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
tie rods are fine they are suposed to twist at the ball. it should be tight at the bolt through the spindle mount. but twist is ok.
did any of you check your steering box mount? you know where it mounts to the frame..this is a comon breaking point that will give you that creak or pop sound when broken. drop the box and look at the frame it may be cracked there. take it to a good welder and have it plated and you;ll be good to go.
jeff
Old May 30, 2005 | 04:58 PM
Car: 1990 firebird
Engine: 3.1 v6
can u see if its broken without dropping the box? i see nothing if so. I hear it more on my pass side though. When i launch hard i can hear it and then i hear it again when i let go of the gas.. like if something gets stuck up then falls
Old May 31, 2005 | 01:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
How are your trans mounts? Those went bad with a buddies camaro and made noise at takeoff and braking etc...
Old Jun 21, 2005 | 02:06 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
just wondering if you ever figured the problem out?? I have a very similar issue.
Old Jun 21, 2005 | 06:41 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Man sounds like lots of you guys are having this problem. I hope you guys figure it out.
Old Jun 21, 2005 | 08:33 PM
Car: 1990 firebird
Engine: 3.1 v6
sorry no luck, i tightened up the kmember to spec. I really think it has to be the upper strut mounts.
Old Jun 25, 2005 | 03:50 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
My car used to have a popping noise during slow bumps and turning mine turned out to be the steerings idler arm
Old Jun 25, 2005 | 04:08 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
replace the trans mount. My Camaro did the same thing, at first it only did it at hard acceleration and hard braking, but then it started to get worse, then it started to make the noise on every bump I hit, I checked the trans mount but the trans mount LOOKED fine, I figured what the hell there only 10 dollars, I replaced it and the noise has stopped.
Old Jul 1, 2005 | 12:24 AM
MOTOCROSS's Avatar
Car: 1984 Z28
Engine: 355
Make sure your panhard bar is tight on both ends. Happened to me.
Old Jul 3, 2005 | 02:24 AM
glintscollide's Avatar
im haveing the exact same problem.The suspension on my car is terrible.but what ive been gettin told by numerous ppl that its my u-joint.
Old Jul 3, 2005 | 02:54 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
FirebirdNYC
I had a transmount go bad where the rubber physcially seperated from the metal part of the mount. I lifted the car up and it "looked" ok. It was more of a clunk than a pop and you could feel it in the gear shifter. It got so bad that on acceleration the gear shifter would raise up and then go back down. So i raised the car again and dropped the tranny mount and support and the metal part of the mount moved while the rubber part was still stuck to the tranny. Also make sure your bolts that secure the tranny to the support are torqued to specs.
I noticed that when i get out of the car sometimes, or when i rock the body in the front i hear a creaking, sharp clunk. I think its coming from the bushings in the lower control arm.
The other thing i had go bad was a strut, the car wouldnt handle right and it would make a clunking/rattling sound at the wheel, and when i pulled the strut off all the nitrogen gas had come out of it, the only thing holding the car up was the spring.
Old Jul 6, 2005 | 11:52 PM
BorderPatrol's Avatar
Car: 85 Camaro
Engine: 305 4bbl
Transmission: th700r4
Strut Mount
These cars are not getting younger. The aging, and in my hot climate, dry rotting suspension rubber is as much a victim as yankee cars are to rust. Several years ago i suffered from similar popping, after looking through and replacing several bushings I came to replace the strut mounts. I had only wished i had done it sooner because it greatly reduced popping. During my inspections at that time i found that my "frame" too was cracked and was causing the sound. After some upside down welding the car does not sound like the clunker some believe these cars to be.
I really reccomend replacing the strut mounts to everyone, while i was in there i threw in a new set of struts, and with everything else done gave my car a much better feel.
Old Jul 12, 2005 | 03:13 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Mine was doing this too and it ended up being my swaybar endlinks were trashed.
Old Jul 18, 2005 | 11:13 PM
Car: 1990 firebird
Engine: 3.1 v6
eh im lead to beleive its my struts, stupid kyb. i kind of been ignoring it lately , hell it probably fixed itself haha. not waisting anymore money on my v6. saving up for something worth it like a 5.7
Old Jul 19, 2005 | 07:12 AM
laiky's Avatar
Whats up Chris?
check the front torque arm mount, es makes a good poly one. If the rubber is beat, the TA will swing up on the gas and down off the gas giving you a thump aech time
RazorN8
Jan 7, 2022 11:44 AM
Street Lethal
Apr 30, 2019 12:14 PM
Out-Cast
Aug 22, 2015 07:49 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
