s.f.c---help!!
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
s.f.c---help!!
I got my connectors and have no idea where to connect them...lol
One of them is straight and the other one is bent. If someone has a picture or can just describe where to connect them that would be great!!
Engine: 383 tpi
I will post a pic as soon as i can....one is crooked and one is straight. One end has a bracket welded to it and one end is just flat. Both ends are drilled for the bolts..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The ends with the holes go along the frame rails at the rear, and the LCA bolts go through the holes. the straight one goes alone the driver side, the crooked one goes up the passenger side.
