F-41 and Iroc-z Same springs?
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I have an 86 sports coupe I rebuilt the suspension added koni shocks, replaced lower control arm bushings( should have used urthane bushings) Used some kind of performance strut( forgot name brand) added 23/24 mm rear bar, quick ratio gear box. am I close to a stock Iroc? I know I need to put the bigger sway bar up front and a wonder bar.
F41 is an RPO code for the suspension setup. I'm not sure exactly what the specs are of each component of the F41 suspension setup, but I do know there were other RPO's for other suspension setups. My '89 IROC-Z for example had the FE2 suspension setup which was supposed to be the better of the two. I'm not sure if the F41 setup ever came in an IROC-Z, but I'm not an expert at this or anything so I'm not gonna say its impossible. I recommend searching all forums for both "F41" and "FE2" and see what other people have said on the subject.
Ok I will search those thanks! I did contact Tom at house of Camaros, he said the the standard Iroc and f-41 are the same springs.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
according to my notes from when i was looking at springs, moogs replacements are the same between the two... i donno if that really means anything though.
MrPackstin
Oct 25, 2017 08:09 PM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
