ReBuilding FrontEnd.
Old Jun 19, 2005 | 01:35 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Hey,
I Just recentley got a job at olympic brakes(parts warehouse)
and i have horrible suspension set up.. the owners b4 me never greased the suspension.My Question to you is that since i get all the parts at wholesale price, what do i need to do? Ball joints?Tie Rods? z28 steering box? what would really help me rebuild the front end? I have the DropZone springs and Monore sensatrack struts.
Thanks.
Old Jun 19, 2005 | 01:41 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Yes, lol, you should do ball joints, a- arm bushings, tie rod ends ( if needed), sway bar end links, springs, and struts. That should just about take care of the entire front end.
Old Jun 19, 2005 | 06:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
And idler arm, center link, sway bar bushings, perhaps a rag joint for the steering column, maybe strut bearings, wheel bearings. Add a "wonder bar".
Old Jun 20, 2005 | 11:36 PM
a- arm bushings how hard is that gonna be? that looks pretty heavy duty work.
Old Jun 21, 2005 | 12:07 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
the A arm bushings are gonna be a kick in the pants if you dont have acess to a torch or a press. torch the bushings and after tehy get hot enough they can be pushed out and the sleeve can be crushed up. a press to put them in but ya need something to support the open side of the arm as it will crush when your putting the bushing in if you dont.
i would HIGHLY recommend you take them off and have a shop do the bushings and ball joints. its wrth the money.
as for parts, i would replace everything all at once. no need in here and there replacing stuff as it goes out. that can be a PITA and will cause you to spend much cash on an alignment each time.
as for the parts them selves, get MOOG hard parts and energy suspinsion bushings. DO NOT get one of the PST kits as i had one and it dosent come with everything. my ball joints didnt fair well as did one of my tie rod ends. tie rod dropped out on me one night and yes i keep everything well greased and maintained.
you will need struts, A arm bushings, sway bar bushings inner and outer tie rods W/ sleeves, center link and idler arm. have your strut plates inspected also. its the black thing the top of the strut lives in when you open your hood. it has a bearing in it and can wear out .
as for a steering box , buying a used one can be a good thing or bad. if you get one off a low mile or well maintained one you could be ok, or you could get one thats sloppy. check yours first and make sure its ok first before spending the cash.
Old Jun 21, 2005 | 12:11 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
does anybody make a rag joint eliminator for our cars? i know unbalanced makes one for 4th gens. but it prolly wouldnt be too hard to make yourself, thats prolly what im gonna do
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
