How important are these?????
Old Jun 27, 2005 | 06:54 AM
Hoosier Bob's Avatar
Car: 84 Trans Am
Rebuilding front suspension on an 84 T/A. Putting control arms back on and spindles. Got new struts to put in it but one of the shields that rides on the strut to cover the shaft is damaged. Are these shields important andhow hard is it to find them? It mounts on top of the strut shaft and is just a large tube to keep dirt and stuff off of the shaft.
Thanks,
Old Jun 28, 2005 | 01:07 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You are talking about the dust shields for the struts. The GM part number is 14019320. $17 shipped each from www.gmpartsdirect.com.
I would tend to want to use them to keep dust and debris off the moving sections of the struts. I do not know of another source other than GM. You may want to look at sourcing them at a salvage yard to save some money.
Old Jun 28, 2005 | 04:04 PM
FatherFrank's Avatar
Car: '90 Firebird
Engine: 383
Also, as a much cheaper alternative, you can get Rancho shock boots from Summit, which should work just fine. (Someone correct me if they don't fit)
Old Jun 29, 2005 | 07:30 AM
Jade Grey's Avatar
Engine: 305TPI
I believe that this search at Summit, http://store.summitracing.com/defaul...=egnsearch.asp, is what FatherFrank meant to post.
Old Jun 29, 2005 | 05:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto. I went with the Red Rancho boots.
Old Jul 5, 2005 | 09:20 AM
Car: 84 Trans Am
Great, Thanks
Thanks for the info. I think the red Ranchos would look great since we have repainted the suspension parts black. Gonna order them today.
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
InfinityShade
Sep 5, 2015 06:38 PM
Ozz1967
Aug 16, 2015 10:23 PM
