rear end number confufion
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i looked up my rear numbers in a haynes manual and it said my rear was from a 1988-89...would this be correct or did someone swap rears....the axle code is...6HK...3.08 std is in the book for it
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Chances are the housing is from 88-89 but that doesn't mean the insides are. Pull the rear cover and see what carrier is inside. Count the teeth to see what gear ratio it is.
You might have a 1989 housing with the 1992 28 spline axles installed into a posi with 3.73 gears.
On the other hand maybe someone broke the original diff and just yanked the first one they found at the auto wrecker and installed it.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
