steering column
Old Jul 28, 2005 | 09:20 PM
UnderKule's Avatar
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
steering column
OK, I just pulled my column apart to try and tighten up the tilt screws that always come loose on the third gens. While i was in there i bought new bearings for the upper shaft so you would think everything would be cool.......wrong!!!!!!
Has anyone else had this problem? although the column has less play in it, it is still loose when you put pressure on it. It is loose enough to release the tilt arm lock and allow the wheel to be pulled down without pulling the release handle (it comes free when i put more than average pressure on it). I have taken many columns apart before and i have a service manual so i know everything is installed correctly.
Any one know of what else could be worn or loose?
Thanks,
J.P.
Old Jul 31, 2005 | 02:50 PM
UnderKule's Avatar
Problem fixed thanks anyway
J.P.
Old Aug 6, 2005 | 12:48 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i just want a good new tight column.mine is way too loose even after retightening and redrilling n tapping
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
