Squeaky Suspension
Old Aug 5, 2005 | 05:07 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Squeaky Suspension
Well the car is showing some age...
The rear suspension started to squek from the right side and now its on the left and its time i do something about it.
What bushings are normally the ones to be squeaking...
The right side sway bar has a poly end link that broke on the first day of putting the car in turns(wasnt a very smooth road) and i think im gonna put the other end link with it in place of the stock right side link.
A guy i talked to said you can use some kind of medical needle fill it up with a grease and inject it into the sides of the bushings and once it wears itself in it should fix the squeaks? anyone heard of this?
Can anyone link me to some kits outthere to replace old bushings?
And what kinda grease can i use to stop the squeaks for a decently long time.
I used WD-40 but the stuff goes away in less then a day.
Any help will be appreciated
Old Aug 5, 2005 | 05:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
go the spohns website and get the poly bushing grease, then grease those suckers up
Old Aug 5, 2005 | 05:39 PM
Stevo's Avatar
I see the grease...how do you actually use it to lube how to you get it in the sides? The way i suggested with a needle? is there a tool for this?
Old Aug 5, 2005 | 05:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
buy a grease gun, if theres no nipples to grease it up, pull them off and give it a greasing
Old Aug 5, 2005 | 06:37 PM
Stevo's Avatar
gotcha
thats what left me confused...cause its not like tie rods or anything
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
