front vs. rear gta rims....
Old Aug 10, 2005 | 07:20 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
ok guys im having a brain fart here.....
i know i should know this too, but anyways,
i can pick up a set of 4 rear gta rims for cheap.....
can the rears be used on the front with a spacer?
if so where can i get said spacer from?
i know the difference in the offset is 16mm rear vs. 0mm front, and about an inch of backspacing.....
if anyone could help me out, id like to pick up these rims for my car.....if they won't fit i'll probably just end up buying all new ones lol.
Old Aug 10, 2005 | 11:32 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
16mm is ~5/8", so you could get close with a half inch spacer on the front. Not sure if that'll still make it clear though. Check your clearance to the tie rod end and that should give you a good idea.
Make sure you have ARP long studs on the front though so you get proper thread engagement on the lug nuts.
Old Aug 10, 2005 | 01:14 PM
Car: '91 Camaro RS
does anyone sell a spacer that will work for that??
like the bolt-on style that aren't just a slip on spacer?
those seem like a much better idea to me
Old Aug 10, 2005 | 01:21 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
5/8" is not thick enough to make a 'bolt on' spacer.
Old Aug 10, 2005 | 01:24 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
http://www.skulte.com/product_info.p...products_id/58
He'll do 3/4"
Old Aug 10, 2005 | 02:07 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
From the skulte website FAQ's:
Can you machine adapters thinner than 3/4"?
In order to have the proper strength for the lugnut and stud seats, the thinnest bolt-on adapters we'll machine is 3/4". Be advised that anything thinner than 1.25" will have the lugnuts sticking out past the face of the adapter, and requires cavity back rims where there are pockets in between the lugnut holes.
Old Aug 10, 2005 | 03:04 PM
Car: '91 Camaro RS
thanks for the info guys
Old Aug 10, 2005 | 03:12 PM
nape's Avatar
If it's strong enough for a race car, it's strong enough for a street car.
Old Aug 10, 2005 | 03:17 PM
Car: '91 Camaro RS
well they aren't allowed at the track anyways
Old Aug 10, 2005 | 09:52 PM
nape's Avatar
What track doesn't allow spacers? Are you talking about drag racing or road racing? Lots of LS1 guys use them at the drag strip to make Pro stars fit with minimal grinding at the drag strip and I know they've been used on road courses for a long time.
Old Aug 11, 2005 | 06:38 AM
Car: '91 Camaro RS
if they see a wheel spacer, you fail tech.
if you can convince them its an adapter maybe it would fly, but no spacers....its expressley prohibited.
specifically im talking about new england dragway which is an IHRA track
Old Aug 21, 2005 | 06:05 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Do you have an IHRA book handy? This is from the NHRA book,
Do you still launch your car at 6K rpms?
Old Aug 21, 2005 | 07:52 PM
Car: '91 Camaro RS
ok maybe it was in the "street night" rule sheet from a year or 2 ago that i read that.
but seriously people, they are failing people at tech now for not having bolt on high pressure style valve stems on stock front rims with radials....on cars 11.99 and quicker with tubless tires.
i understand that on an aftermarket style rim, but there are factory cars that can theoretically get tossed right off the showroom floor now.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
MORREALE5
Sep 13, 2015 09:16 PM
Street Lethal
Aug 14, 2015 08:25 PM
