Anyone have this front strut.
Link to them https://www.cachassisworks.com/DataS...952_DS_WEB.pdf
I have Koni spa-1 adj. struts with Morrison coil over kit and Eibach springs. this looks like a big upgrade.
Jerry
Jerry
Very nice find Jerry. It will definately be the next struts and shocks I use, but the fronts I'll use without the coilovers.
I do still want to got to coilovers on the rear since I have welded in the provisions for it a few years back. I have a Koni yellow with a squeaky rubber I bushing and a screwed up I thread mount so I can not remove it- cheap *** threads that Koni does and I didn't catch it before I threaded the nut onto it. Pain in the rear (pun intended). Any rain and I have to climb under there and try to lub it best I can. I am definately going to solid mount shocks next to get rid iof the shock bushing squeak and low motion play.
Dean
Dean
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Very good find.
Any idea what the price range for the non-coversion strut is? I found the price for the coil-over conversion, but nothing for just the strut.
John, it appears to me that the $875.00 price tag is just for the two front struts without the springs. They only have the spring pictured for display, you buy them separately if you want that route.
How I figured this is I looked at the rear SHOCK coilovers compared to the smooth bodies. They are the same $648.00 per pair for those based on whether you want threaded body or smooth- then you buy the springs separate if choosing the threaded coilovers style.
For just under $1500 you can get all aluminum double adjustable struts and shocks- decent price.
Heck, go to Penske aluminum 4ways and you are looking at over $4000 for 4 shocks, noit 2 shocks, two struts. Struts are more expensive.
Dean
Dean
Car: 1990 Camaro RS
I didn't see any pricing for springs or hardware on that though. I saw the pricing for Double vs single adjustable, but it was listed on the coil-over conversion section of their e-store. I was not able to find them listed any other way. Guess we will likely need to call or e-mail to get a final answer.
(Dean, yes I realise it is a descent price point, I was just wondering what kind of price point these were at, as in, if it would have the pricetag of something like a Penske. (Am I the only one who gets wood, thinking about the Penske parts.
)) Originally posted by V6#20
Dean
Dean
Jerry
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
