Por 15 and New Moog Steering Parts?
Old Sep 27, 2005 | 04:30 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I know that Por 15 does not bond that well to painted surfaces. For those who have used Por 15 on there Moog (or any new steering parts) did you have to grind down to bare metal? The only reason I am asking is the paint or oil they put on there does not seem very thick and wanted to know it the Por 15 could go right over it.
Kevin
Old Sep 27, 2005 | 08:10 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
use some wd40 and degrease them, it should stick after the wd40 evaporates and the grease/oil is wiped off
Old Sep 27, 2005 | 08:38 PM
Engine: L98 350 TPI
I ended up using brake cleaner and a wire wheel. Worked pretty well.
Kevin
Old Sep 29, 2005 | 02:59 AM
83 Crossfire TA's Avatar
WD40 is a light machine oil in kerosene, all you’re doing there spraying the parts down with more stuff that POR 15 won’t stick to.
Just use a strong degreaser… most used full strength will strip most protective coatings including light paint…
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
