T56 cross member question
Car: 85 Z28
Engine: LS
Axle/Gears: 9inch/3.50 gears
I bought a t56 and the spohn torque arm/cross member setup off someone and now i bought a different camaro. Its a 91 with a moser 9" rearend, tubular control arms, sub-frame connectors, and a 6 point roll cage. Now I can't use the spohn stuff and it wouldn't bolt up if i wanted it to.. Does anyone have any clue if i can just use a stock cross member from a T5 or do i have to get an after market one?? Or.. will i be able to just use the cross member from my torque arm setup and just sell the torque arm?
thanks
thanks
You could run a Skulte T56 Xmember and keep the torque arm mounted to the tailshaft of the tranny. I didnt like the torque arm to Xmember design so I'm selling my Spohn kit too. Ground clearance also had alot to do with it.
Car: 85 Z28
Engine: LS
what I've been told also is that I don't even need a torque arm anymore with all the goodies this 91 has. I don't know if this is true or not... Where can i find a skulte cross member?
