V8 Sways on a V6
Old Oct 18, 2005 | 07:06 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
V8 Sways on a V6
like the title says i want to put larger V8 sway bars on my V6 car. Does that create any issues with the other suspension parts? I know its only a 6 but i like to corner so i will be stepping up the rear control arms, torque arm and pan etc etc. Those components are car specific right? It does not matter what engine i have does it?
Old Oct 18, 2005 | 08:33 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have a 34hallow, and 24 solid on mine.
Do not put the 36 on, it will be to much unless you order the spohn 25 rear.
Main thing, install with new polly bushings everywhere.
Old Oct 18, 2005 | 11:34 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i have the same combo on my 2.8. thing HUUGS
Old Oct 19, 2005 | 01:36 AM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
so 34 front 24 rear are those stock replacements or aftermarket?
# Front Sway Bar,1982-92 Camaro/Firebird
# 1-3/8'' Dia.
# Rear Sway Bar
# 1" Dia.
so uh does anyone know what that is in milimeters?
Old Oct 19, 2005 | 05:45 AM
Dale's Avatar
Engine: 350 S-TPI
yes, these are all oem pull offs/junk yard units
24mm=hair under 1"
34mm=1.34" (they have solid and hollow versions of these)
1"=25.4mm
36=1.417
34=1.34
32=1.26
20=.787
21=.827
22=.866
23=.905
24=.945
25=.98 (sphon aftermarket, some same gm made a very rare limited version. no one has proven this.)
J-money
Jan 4, 2019 09:45 AM
J0386
Oct 12, 2015 07:46 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
87camaro87
Sep 9, 2015 10:29 PM
