tires pleeeeze
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
tires pleeeeze
does anyone have any pic's that have 275/60's with standard ride height? I'VE GOT 245'S all around, and would like to go to a wider tire in the back.......
Car: 89 iroc
okay before I get blasted about doing a SEARCH...
I found some pic's of the 275's.
question though, do we have to do any moding to the wheel well area for them to fit?
By the way JungleMan and ZZ4 86 that is exactly what I'm looking for, nice rides
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Are you sure you want 275/60s I think most 275's are 275/45. You will end up with the speedo way out with 275/60. And in my opinion it'll look daft....
Si.
Si.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
mwnova has it, and it looks good IMHO.
I have them, on 2nd gen wheels, so the offset might be a tad off. My car is in many pieces, so I can't get a picture, and apparently I never took one before...?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
