shocks/struts springs
Old Nov 10, 2005 | 08:48 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
what are some good shocks/struts i can get that are as close to stock feel as i can get and also mabey some springs close to stock also dont want it lower than normal if possible and would like to keep the ride as smooth as stock not a pebble throwing me all over. just wondering i know i can find a set but just want others opinions since this will be the first set ive purchased for this car and what should i be looking to spend thanks
Stokley
Old Nov 10, 2005 | 01:08 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
struts shocks
if you want to go cheap there is a complete set forbuy it now price of $129.99 plus $34.95 shipping
Old Nov 10, 2005 | 06:04 PM
Engine: 305 tbi l03
it dosent have to be real cheap just as close to stock as far as stiffness and feeling for a decent price i just meant i dont wanna jump for some blistens or anything and i wont need adjustables cause its just a daily driver not a strip car or anything.
Old Nov 11, 2005 | 05:37 PM
w1964bgta's Avatar
shocks struts
Go on e-bay dude.
Old Nov 11, 2005 | 11:16 PM
CrazyHawaiian's Avatar
Car: too many ...
If you just want stock replacement feel I would do MOOG replacement springs and some OEM replacement struts/shocks from the local parts store (Monroe brand or something similar). If you wanted it to ride better than OEM replacement I would go for some semi-good aftermarket struts/shocks for those MOOG springs, somewhere in the $150-250 a set range. Also consider replacing the bushings if they are shot, this really affects the quality of the ride (along with the struts/shocks).
Old Nov 12, 2005 | 08:50 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If you've got the money, do a complete suspension rebuild. Once you're already replacing all four springs & dampers, it's only ~$150 to replace all the bushings with ES polygraphite units. I did this and it felt like I gained about 30 HP off line line because everything was so tight.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
