Torque arm delete?
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
Torque arm delete?
If I install these http://store.summitracing.com/defaul...=egnsearch.asp will I be ok to run without a torque arm? I recently swaped rear ends and one of the people helping me tossed the bushing that go to the rear torque rm mount. I cant find the bushings for sale anywhere and I would rather not spend a ton getting a new torqu arm. I heard of one guy on here saying he went with LCAs and got rid of the torque arm and was ok.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I dont really understand what you are saying but the link to the SummitRacing website that you just posted has 8 different TQ Arm bushings for sale. I really dont think that your car will be able to make it through the first few redlights before your u-joints, lca's, or panhard bar snaps. I dont know for sure though b/c i have never driven a car with out a TQ arm. I had a 84 that the TQ arm broke at the tranny and by the time i got it 2 the house (2 miles away) it had nearly slammed a hole through the floorpan. Someone else might chime in that knows alot better than i do.
Car: 1987 Z28
Engine: 350 (357ci)
Sorry I hit cntrl v and didnt realize I had the wrong link on the clipboard.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Install one of what? Still wrong link.
The torque arm keeps the diff from rotating. Without it, the first time you try to accellerate, the pinion yoke will twist upward and cause a lot of damage.
Third gens use torque arm suspension. The LCA are like the bottom bars of a 4 link system and the torque arm is like a 4 foot long ladder bar.
Mustangs, G-bodies etc use a triangulated 4-link system. The upper and lower bars keep the diff from rotating. First and second gens use leaf springs so the diff is clamped directly to the springs keeping it from rotating.
Car: 1987 Z28
Engine: 350 (357ci)
They are lakewood LCAs part number LAK-20140 at Sumitt
I guess I will just have to break down and buy a whole new torque arm. I pretty much knew this was the route I had to go I was just trying to talk myself out of it. I cant believe my next upgrade is going to be something I didnt have to have until some asshat threw away parts.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I still see 8 different TQ Arm bushing for sale all around $11.00. What part are you talking about that your friend threw away. Your saying bushing but you say you cant find one?
Car: 87 IROC L98
The torque arm bolts solid to the diff. 2 bolts go through the torque arm and through the diff housing. They're supposed to be torqued to prevent case deflection for the pinion.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
http://store.summitracing.com/default.asp?Ntt=torque+arm&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=115&target=egnsearch.asp
These are still on the summitracing page you posted.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 87_Z28_350
On my camaro there are two metal bushings that go between the mount and diff.
theres a couple washers that go on the bolt.but it bolts SOLID to the rear.
there are no bushings between the TQ arm and the diff.
Car: 1987 Z28
Engine: 350 (357ci)
My original 87 rear did not need the bushings because it mounts flush. The rear end I put in has a gap and requires metal bushings to fill the gap. I saw the bushings when it came out so I know they do exsist.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Those aren't bushings, so much as they are spacers, about 1" or 1¼" in height. The 3 10-bolts I have here all have them (2 are 83's and the other is an 86).
Maybe the 9-bolts didn't use them, or later 10-bolts were modifiied to eliminate them?
Car: 87 IROC L98
Someone already beat me to it. They're spacers not bushings.
My car originally had a 9 bolt and never had spacers. When I swapped in a 10 bolt, it didn't use spacers either or at least I don't think either one did. I have a 9" with ladder bars now so that was a long time ago.
You can always go to an auto wrecker and pull the spacers off another third gen. Since the bolts come down from the top all you need to do is take the nuts off and pull the bolts up enough to get the spacers out.
Car: 1987 Z28
Engine: 350 (357ci)
Originally posted by 91GTABird
$11.00 on the same summit page.
I need what Pete said, thanks for the pic.
I thought about getting them from a junkyard but they sit up in the diff about an inch or so and most likey will be stuck in pretty good. I will probably end up going the junkyard route, I was just hoping I could find some replacement ones.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Would them not be able to work though? I really have never seen these spacers before but good luck on your search. Take alittle beating hammer with you when you go to pull em'.
Ragtop Man
Sep 12, 2015 12:23 AM
