camber angle
Old Nov 27, 2005 | 09:15 AM
eric1984z28's Avatar
Car: 1984z28
Engine: soon to have ls1
Transmission: soon to have t56
camber angle
what mods are needed to the strut tower to get 6-7 degrees of camber out of an 84 Z? also what parts? the car will be lowered 1.5-2 inches with adjustable arms and coilovers.
Old Nov 27, 2005 | 09:25 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Do you mean camber or caster? Aftermarket adjustable strut mounts and probably a little trimming of the hole the strut goes through. It's also possible to cut off the strut mount plate and move it back, but seems like alot of work.
Old Nov 27, 2005 | 09:39 AM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
That is not a reasonable amount of camber. What is the point of your doing that?
Old Nov 27, 2005 | 09:51 AM
Car: 1984z28
oh sh**, my bad i mean caster. sorry get em mixed up sometimes. looking for about .80 on camber and i think thats supposed to be negative camber...
Old Nov 27, 2005 | 02:00 PM
Lo-tec's Avatar
You can get over a degree of camber stock, but only 3 to 4 degrees caster. With aftermarket strut mounts 6 to 7 degrees of caster is possible.
Old Nov 27, 2005 | 03:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
After doing a bunch of front end modifications last winter, I took my car into an alignment shop to get everything readjusted. Toe and Camber are roughly stock or zero but I wanted as much Caster as possible. Without removing the strut and elongating the adjustment slots, the best I was able to get was 4*. I was trying to get 8-10*.
morrow
Jan 13, 2024 12:29 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
FED 387
Sep 16, 2015 12:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
