27-10.5???
Old Dec 15, 2005 | 06:10 AM
19IROC87's Avatar
27-10.5???
will a 27 10.5 fit on a 87 IROC-Z?
thanks for the help
Old Dec 15, 2005 | 06:59 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
yeah. You can get anything to fit. If you are dragracing you can really fit huge stuff. Or if you don't mind the tires sticking out tinny bit. You can stuff 11" wide rims with 13" tires.
I would know.
Old Dec 15, 2005 | 11:17 AM
19IROC87's Avatar
fit?
will they fit on a car with factory rear and suspension
Old Dec 15, 2005 | 11:43 AM
Engine: LS3
Ummmm. sorta. Not 335s. Def not. How experirnced are you at modding and stuff? If you are a novice stick to 275s.
Believe me, just stick to the smaller tires that fit well. You can put a 275 under there with no problem.
If you wanna know what i have done. then I will give it to you in a nut shell.
-I have and aftermarket 12 bolt rear (same size as stock, (width))
-I am running ZR-1 corvette replica wheels.
-2" addapters on the rear.
-Tons of cutting around the bumpstop.
-Tons of hammering done on the front 1/2 of the wheel well.
-Tires stick out about 2 or 3cm past the fender flare.
There is a LOT more to know, but if you wanna keep it simple, just get some 9.5" wide rims of your choice that are made for these cars and slap some 275s on there.
Good luck.
-Dennis
ps-all the info you want is allready on this website, keep looking.
