lifting rearend?
Old Dec 19, 2005 | 09:22 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
lifting rearend?
does anyone make taller springs to make the rearend sit higher
Old Dec 19, 2005 | 09:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why would you want to lift it? and you can get cargo springs for the rear for some lift.
Old Dec 19, 2005 | 10:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Get a set of rear 4thgen isolators. Should be good for an inch.
Old Dec 20, 2005 | 06:26 AM
Car: 82 z28
Transmission: TH350
yea i know its odd but i like it to sit up higher and the front already sits up high enough from all the weight ive takin off the fron end i just need the back to sit like in inch higher than the front i found some high lift springs from jc whitney but ive never been to happy with jcw products
Old Dec 20, 2005 | 10:05 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You can get aluminum spacers that go on the rear to space the spring up an inch. I've got a set, part # 1627 is cast in them.
Old Dec 20, 2005 | 01:35 PM
Car: 82 z28
Transmission: TH350
wher is that from?
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
