SFC question
Old Feb 6, 2006 | 08:35 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
SFC question
Ok my car is a 91 camaro..ive swapped in a LS1 + T56. what sub frame connectors are going to work best for me? (with no exhaust interfernce and preferbly bolt in?)
Thanks,
Brandon
Old Feb 7, 2006 | 05:57 PM
Shagwell's Avatar
Car: projects.......
hard to call w/ the LS1 swap. Much off that depends on how you exhaust is rooted/who designed/installed. - Also, don't go bolt in. Most half decent exhaust shops will weld then in for you for cheap enough and then you won't have the problems related w/ the bolt ins. - Just make sure they weld them in w/ the car sitting on its wheels. I did mine(home built, very different style) w/ a jcak on both sides in the middle of the car, slightly lifting on the body. Pre-loaded the car back up some, but it's a rag-top, so I get "sag" over-time.
Old Feb 7, 2006 | 10:11 PM
Camaro0605's Avatar
Car: 1991 RS
I have spoons SFC's ready for install with my swap. However the subframe connectors are going in long before the exaust will be done so i'm not sure about clearence with your exaust. The quality of them is real good.
MustangBeater20
Oct 29, 2022 09:20 PM
kairles
Oct 26, 2015 09:13 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
