Back spacing question....
Old Feb 16, 2006 | 09:14 AM
crawlin 25th's Avatar
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
I just got some prostars for the rear of my car and the guy that worked at the store said i should have a 5.5 bs on a 15x8 .... Now i did a search and seen that most ppl run 4.5 on an 8 inch rim ...How will this affect clearence with a 28x10.5 et drag and will it look right???? Thanks for all of your help in advance....
Old Feb 16, 2006 | 10:11 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I use to have 5.5BS prostars on mine. 5.5 actually tucks the tire in more and looks better in my opinion. You have to make a little room at the front of the rear inner wheelwell at the bottom (big hammer) Other that that they will work perfectly
Old Feb 16, 2006 | 11:17 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
I just posted this in another topic but here it is again...
I have 15x8 weld prostars with 5.5 b.s. and i am running M/T ETStreets that are 28x11.50. I had to do a little pounding to the inner fenders just to make sure they didnt rub on a hard launch.
Here is a couple of pics to show what they look like.
Old Feb 17, 2006 | 08:53 AM
Car: 92 z28
Transmission: th400
Looks good man!!!! Im sorry for not looking at the recent posts , But thanks for ur input ....
Fronzizzle
Mar 18, 2019 08:29 PM
neekolzun
Aug 24, 2015 04:59 PM
kah992
Aug 19, 2015 02:55 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
